New design
this is project: "loose screw"
Frame:1/2"poly, black vinyl stretched over, with carbon fiber over lay
Suspension: custom 4 link. Rear lower links: 1/2" poly,145mm, 30 degree
Front lower links,1/2" poly,125mm, 20 degree.
Upper links,front aluminum 100mm
Rear upper:120mm aluminum,
Shocks: 103mm gmade piggyback
Axles: front graphite c-hubs, graphite knuckles, beef tubs, overdrive gears, custom carbon fiber/poly four link mounts.
Rear axle: pretty much all stock other then the carbon fiber/poly four link mounts. (Dlux trusses are in the mail).
Wheels: gmade 2.2 GT, rear weight:none. Front weight : ten ounce.
Tires: 2.2 ripsaw custom cut,
Drive train: 60t rc4wd motor, pinion: 20t, spur:93t. Locked axle kit.
Servo: junk......digital tactic, ordering a 7980 next week.
The frame was just a "trial chassis", but now I have the chassis layout so I'm cutting one out of carbon fiber.
Sent from my SM-G360T1 using Tapatalk
Oh yeah......esc, ae-2,
Battery: 800mAh 20c 7.4v venom flight pack. I love this battery.....1.7oz, around 20 min run time.
I chose to run the stock esc because of the run time and how smooth the electronics run, nothing gets hot...never gets above room temp.
