New RC4WD Products at The Crawler Store - www.tcscrawlers.com
EeePee
MODERATOR™
Moderator
Ohio
TracGear Spool Locker for TLT-1 & F-350
- Super rugged aluminum construction
- Manufactured with advanced internal spline technology
- Engineered & manufactured by RC4WD
- Optimized for severe driving conditions
- Direct fit for Tamiya TLT-1 & F-350
Conventional "open" differentials tend to equalize the power delivered through both wheels. Thus if one wheel loses traction - "spins out" on snow, mud, sand, or gravel - it delivers very little power to the ground. The other wheel will deliver only very little power. Often this is not enough to keep the vehicle moving - it's stuck. A locked differential or spool maximizes traction by delivering 100% of axle torque and power to both wheels.
1x RC4WD TracGear for TLT-1 & F-350 - $34.99
Raptor Crawler Black Axle
The Raptor axle is the most advanced crawling axles on the market today. It utilizes micro size hardened gears to ensure it's ultra compact size. The Raptor axle is light, beefy, compact and offers maximum ground clearance.
- CNC machined aluminum housing
- 10:1 to 30:1 Gear Ratio (with 8tooth pinion gear)
- Hardened steel gears
- Heavy duty stainless steel drive/axle shafts
- Huge heavy duty aluminum axle tubes
- Use 32 Pitch pinion gears (8 to 20 Tooth)
- Monster size clear dust cover for fine tuning gear mesh
- Fit 12mm wheel hex
- Designed for 1/7 to 1/10 scale size trucks
- Engineered by RC4WD USA
- Full metal shield bearings
- Width: 290mm / 11.4inch
- Heigh: 51mm / 2inch
- Weight: 411grams / .9 lbs
What's included:
1x Raptor Black Axle
1x Aluminum upper 4 links posts
2x Drive & axle shafts
2x Aluminum knuckles
1x 8 tooth pinion gear
1x Clear dust cover (PVC)
Note: For a complete truck, you will need 2 of these axle
Note: Raptor axle uses a spool instead of a differential. It is designed for off-roading use only.
1x RC4WD Raptor Crawler Black Axle - $129.99
RC4WD 32 Pitch Pinion Gears are $7.99 each
6 Tooth pinion - 7 Tooth pinion - 9 Tooth pinion
Aluminum knuckles for the WK and the straight axle adapter for the TLT are coming very soon.
www.tcscrawlers.com
"thumbsup"
