Johnnysplits
What's the wheelbase?
May not be the ideal place for this question, is there a "better" bias front of rear to lengthen the 4 link? Longer fronts vs rears? Suppose its only preference on c.o.g.?
Hey man would this work? Punisher Shaft II (150-192mm, 5.90"-7.55") 5mm hole
Dual motors is the best upgrade i have done. It allows high gearing and speed with low motor temps with smooth low end and amazing torque. I run on 3s and 2s and power and speed is very close to my friends novak brushless sensored but is way smoother on the low end. I run one esc and have convinced 3 other of my buds to run dual after trying mine all with no esc problems. We just run a fan to be safe. Do it! Youll be happy you did.
Are you just running the motors to the single ESC in parallel? I thought about doing this set up for a really heavy rig I have, but didn't want to invest in a dual motor esc.
Still building...I'm not even close to running it yet. It'll be a few more weeks. All I know is this...I want to run two lipo's in parallel and I know where I want to mount them. Do you happen to know what the rpm difference is between a 27T and 35T?
K so might not be exact but 35t = 1565rpm/volt and 27t=2100rpm/volt so...
At a 4v/cell average
35t on 4s = 25,040 rpm
27t on 3s = 25,200 rpm
Hope thats what you wanted. Motor specs were taken from holmes hobbies motors so are not exact to our application but close enough
