So I have this XR10 here that I got in a trade a long while back whenever I thought I was gonna get more into comp crawling. Well skip a whole year of it sitting on the shelf after the group died down and I decided no point in it sitting around anymore, time to drive this damn thing. Got about 15 batteries through it and boom went the servo on a good landing from a rock. So, finally I have to tear into this piece of alien technology. I have so many questions, so far I've found some of the answers but I need you guys to help with the rest. I will put all my listed questions at the bottom of the pics.
First things first, the rig in question:
As far as I know, it's a Secret Agent chassis, Vanquish axle halves? (the bottom halves are plastics), Vanquish transmission cases, Vanquish upper link mounts, Vanquish knuckles & Chubs. Holmes Crawlmaster 13t? motors, Smashed Sidewinder 1/18 v1 ESCs.
Now, here was the first mystery to me after taking the wheels off... why only half a weight?
*Removes weight from other knuckle* Oh....wtf :lmao:
Ok, mystery #2, here's where I need help...what is this rear axle?
I tried to pull this axle out to investigate, but that thing won't budge at all, so I'm thinking that its somehow clamped in there? Either way, the threaded portion is 5mm and accepts an 8mm locknut, but the smooth portion above it is 6mm thick, and it has some kind of plastic spacer on it.
Oh what fun, whenever I went to unplug the servo I decided the electronics might as well get pulled out. I was greeted with the "rat nest"...
The dead servo in question:
Ok so congratulations, you've made it this far, now onto the questions:
1. Again, what're the rear axles? I seem to be drawing a blank here...
2. Are the Sidewinder 1/18 v1 ok to use or is it just worth upgrading them? If so, Sidewinder V2s or Holmes Minis?
3. How do I mount a body on this thing? Or should I go with those cab panels that everyone else seems to run? For the bodied ones I've seen these threaded rods that clamp to your standoffs but I don't know what that part is or who makes it.
4. Is it worth getting proper knuckle weights or just going to something like the DLux Knuckles?
5. I know the truck has been used a bit and was definitely used before I got it, is it worth sending the Crawlmasters back for a rebuild or how would I know how well they're running?
Thanks for any help, if there's anything else I need to know about this thing just let me know, the XR10 is foreign technology to my newb scaler self. Otherwise, I have a decent to-do list with this rig and it might take a while to get to with so much other stuff going on, so in no particular order: Rebuild shocks, new tires, new motor guards/skids, redo electronics setup, battery plate, new servo, new wheels, new body/body panels...
