From reading the stickies on here I am now confused.
The battery sticky says a Nimh battery will have more capacity for whatever given size, compared to a Nicd. I thought a subC was a sub C. Are Nimh actually smaller or do they just weigh slightly less or something? In all my shopping around it seems most 6-cell standard flat packs are pretty much the same size, regardless of Mah... but the higher Mah look like they weigh more.
It also says a Nimh will tend to drop off voltage more as it discharges vs. Nicd. If that's the case, does anyone have any charts or graphs comparing two comparable batteris (nicd vs nimh)? Is there a noticeable difference between the two here?
I'm thinking about picking up some longer runtime packs and am just wondering other than memory effect, why Nimh is better than Nicd. If I can get a longer runtime Nimh that is the same weight & size as my current 1500 Nicds it seems like a no brainer... unless the voltage drops off a lot more.
