Who uses this setup and why is it used?
I've seen heavy shock oil with hard springs.
I've seen no springs at all with heavy shock oil but never a NO OIL setup.
If you run without a filled shock can, you still need to coat the internals of the shock with oil so that it moves freely.
Well, leafs are springs. So, the shocks only serve the purpose of damping....not damping and suspending like a typical coilover."thumbsup"i know rc bros say that when you use their leaf kit they recomend either not running the shocks or if you do dont run springs or shock oil so that might be another reason
Is it correct to say the heavier the oil weight the stiffer the shock? Is softer better for the front and a little heavier in the rear?
