Offset hex... for a wider a wider stance.
Mt shasta
I want a little wider stance on my wraith. I looked at offset hex bolts by integy and looked like I can go +3 or +5. IF I get this productIntegy Hex Wheel Hub Set +5 Offset Wraith (2) (INTC24396BLACK) | - RC Planet
will the outsides of my tires be wider? I keep seeing posts that say a negative offet makes it wider, bur they may have been talking about wheels..
I'm confused:lmao:
Is there any reason I would not want to use this product to make my stace wider. Will this product even fit the spindle? would I be able to thread on the hex nut with this installed?
anyone out there doing this too?
I want to keep all my travel and not lower the suspension. I want to crawl and trail run this rig. speed is not important.... To me.
they will take an move the wheel an tire farther out from where they r now. i have never an will never buy integy so cant say about how strong or good they r. an yes a negative offset wheel can be used to make it a little wider to.
Hey brother,
The Junfac Wheel wideners are awesome. I lifted my wraith and needed more stance to compensate and used the 19mm blue spacers from junfac. I then lowered the truck again and used the red 13mm and am currently using them and they are freakin sweet! I destroy side hilling, obviously weight is an issue as well but the wideners will improve your skills instantly. These are the wideners I'm talking about.
Wheel Wideners : JunFac.com
Your looking for item number J51032 (RED)
The blue are (J51033)
You will need to BLUE threadlock any wideners you put on them they have a tendency to come loose and you dont want to lose a hex pin on top of a mountain haha.
Another side note on the red is that the wider you make the axles and stance the more area you will be hitting or contact on the axle, it will make it a little harder to clear some gates getting stuck on the wider axles. Using the red I had no issues.
RED Spacers
BLUE (Not lifted)
Blue Lifted
Even got a pic with RC4WD 12mm to 17mm Wheel wideners as well on 40 series Moabs
Hope this helps let me know if you have any other questions
