Farmer91
Got some of the pieces in so I'm starting a new project.
Going to build an offset center front in a couple versions. Leaf sprung and radius arms like a 70s Ford. Axle tube and mount will be steel, and the radius arm will be mixture of aluminum and steel.
The SSD axles came in , I'm pleasantly surprised with how good they look
This is the chassis they'll be going under, RC4WD Trail Stomper, plans are a custom frame later on. Also I'm running a HPI 79 Ford body.
Starting to mock up and take some measurements, to gain any difference to the look, the drivers side leaf spring will be mounted to the center section itself, much like the 84-97 Ford Dana 60s are.
