OzThrasher
First let me introduce myself. I'm 40yo and had a number of RCs when I was young. Now with kids of my own it was time to get the little man his first RC. Now he can't have one without dad having one too.
So after heaps of research, mostly loitering on this site for the past few months, I decided to build a Yeti kit.
A massive thank you to all the members that contribute to this forum and provided me with a lot quality info to put me on the right track.
Having a lot of experience in building 1:1 scale off roaders I have throughly enjoyed getting back into the RC hobby.
Anyway started with ordering a kit and the parts started rolling in.
This is my Yeti kit parts list.
Front end:
Vanquish steering knuckles
STRC caster blocks
Axial machined shock tower AX31170
Axial machined body post mount AX31169
Vanquish steering rack
Vanquish bell crank
STRC Front hinge pin mount
High tensile 12.9 hinge pins
50 000wt diff fluid
HR front sway bar kit - heavy bar
Motor mount and gears:
Axial machined motor mount AX31156
Axial Steel spur gear 32p 64t AX31161
Axial pinion gear 32p 16t AX30842
Axial machined slipper plates AX31164
Rear end:
Axial machined shock mount plates AX31166
Axial machined sway bar clamp AX31167
Axial machined 4 link mounts Ax31165
Vanquish OCP axle housing V2 - silver
Vanquish locker
Vanquish machined differential cover
Vanquish hd axle truss
Vanquish lockouts
Vanquish axle / shock link mounts
Vanquish trailing arms lower - silver
Vanquish titanium rear upper suspension links
MIP drive shaft
VP Currie Antirock Sway Bar
Shocks:
Front spring 14x54mm 4.95lbs-in - Super Firm (blue) AX30230
45w shock oil
Rear spring 14x90mm 1.71lbs-in - White AX30214
30w shock oil
Wheels:
Standard for the time being as I cannot get my paws on a set of VP Method rims anywhere in OZ.
Vanquish SLW wheel hubs
Crawler Innovations Deuces Wild standard
Electronics:
ESC - Tekin RX8 Gen 2
Motor - Tekin Pro4 HD 3000kv
Servo - Hitec HS-7950TH. Hitec aluminium servo horn
Castle BEC set to 7.4v
And the build began.
I put a brass shim I between the outer bearing and the MIP shaft, this stopped all movement with the pinion and it is meshed perfectly with the bevel gear.
I did however have a drama with the inner bearing. I was running a thrust bearing however after half a pack it got a bit of up and down movement which caused the pinion to touch the housing. Back to a standard bearing for now.
I'm absolutely loving his thing. It is beast in the dirt, with Huge power and torque with masses of grip. I've definitely hit the sweet spot with the suspension setup and foams. Just need to sort some rims now, come on VP, send some over to OZ please.
Anyway thanks again and I hope I can contribute to the forum from time to time and help others as you guys have helped me.
Front end:
STRC caster blocks
Vanquish bell crank
50 000wt diff fluid
Rear end:
Vanquish locker
Vanquish lockouts
MIP drive shaft
Shocks:
45w shock oil
30w shock oil
Wheels:
Electronics:
