Parma Clod Lexan Body Fit for SCX10 Link Help
EastTnCrawler
Kodak
I know I've looked at a bunch of posts and no luck...
What length are the links supposed to be for a shortened honcho fitting a parma chevy clod body? All four links not just the bottom.
And yes I know it has to be an inch I've just not found the exact link fitment and don't want to waste money trying to.
Any help helps!
Running 1.9 Boggers (got a little trimming to do with the body... if you have any pics of a similar setup body/tire wise post em!)
Thanks
There is no easy answer.
You need to determine where you want the body to sit in relation to the frame. Shortening all the links equally is probably no the best idea. The honcho is longer in the front when comepared to the standard scx. Shortening the front and rear equally may not sit the body in the ideal location.
Your best bet is to buy the body and determine where it needs to be, and then make/buy links to the length you need.
