xjnation
Any thoughts on this? might be good because of all the available ratios.
The planetary gear box system is a highly versatile system for reduction of high RPM electric motors for high-torque low RPM applications.
This type of gear reduction system is often used in precision instruments because of the reliability and accuracy of the unit. The adaptation of these units is limited only by your imagination. By adding/removing gears in assembly, you can select ratios of 16:1, 20:1, 25:1, 80:1, 100:1 and 400:1.
Operates at 4.5V DC. 15100 RPM.
