Proline Powerstroke Shocks
HannibalLecter said:
Just curious, is anyone using these on their rigs and if so what kind of setup you have going on.
too stiff of a spring and too much dampening.
I use revo shocks with maxx springs. You have to modify the shock a bit and drill out the piston holes a bit bigger. You may be able to do the same with the proline shocks.
Yeah, the stock springs are stiff. I'm just curious, before I spend money on getting the softer spring sets, if the dual rate shocks are a good idea for crawling.
On the dampening, I thought I might have to go with a different hole size and possibly down to 20wt oil.
I just happen to have a set sitting around that I was considering using. Thanks - Anyone else please post your thoughts as well!
