DRED805
I bought a used puller pro stubby a while back, and finally got it hooked up in a truck. It wouldn't work... Sounded like it was trying, and would kinda knock if tried to go forward or reverse.
No binding in the drivetrain anywhere.
I tried a different motor plugged into the esc and it worked fine.
I tried the puller pro with a different esc and the problem was the same.
The motor works fine without the sensor wire, though. I tried a couple different sensor wires and they didn't work, so something is wrong inside the motor.
Has anyone had this problem and fixed it?
