punk rc dig switch 3d
gixerman
House
If I wanted to or possibly if Bully 2 MOA comp crawlers DIG unit fails .. are these still available? I was contemplating a Holmes hobbies esc, but would like to retain DIG ability. Thanks if anyone has and ideas or info.
Dual esc is better than a dig switch. Requires a transmitter with dual esc mixing.
Sent from my SAMSUNG-SM-G920A using Tapatalk
So something like the Holmes dual? How exactly do I select from rear or both then? Just curious how I would accomplish it. Thanks
I have a Spektrum DX4 Pro, so I would have a channel that neutral is both ESC's on the Holmes mini and each of the directions would be either front or rear alone? I was thinking of going with the Puller 500 Flow 35t but would a 5 slot hand wound 16t be better for technical crawling on my Bully 2 MOA? Any info or opinions would be appreciated.
I don't have the answer on a motor but yes if your transmitter allows channel mixing and has a setup for dual esc, that's what I would do. Holmes br minis is the go to it seems.
