Quad port charger
whoodie
Moderator
Moderator
Texas baby!
With my ever increasing supply of batteries I am now needing a quad port charger. I've done a bit of research and I think I've found all the ones on the market that suit my needs (integrated balancing, etc...). I've settled on the HK Quattro but I'd like to hear from some that already have this charger. I'm a firm believer in "you get what you pay for", and well, this charger is pretty cheap. So fill me in, is this a good buy or not? And if not, what is?
I have the Hitec version of this charger, the x4.
If they are indeed identical, I would highly recommend buying one."thumbsup"
I'd try to find out if the 50w power limit is per port, or total. What kind of packs are you charging?
It's 50W per port. I won't be charging anything higher than a 1000mAh 3s for the time being.
One of my mates has one. Works like a charm.
They only thing i noticed is it tends to get warm if you've got 4 packs on at once (sort of to be expected though).
I have the turnigy one for over 10 months and I charger 4 5000mha venon 14.8 4s 35c batterys at the same time using a 20amp power suply with no problen other them a noise coming from the fan on the side!!
