the.ronin
I've got an R2104GF receiver in an Axial Yeti Jr rc rock crawler and a Futaba 4PL radio.
I have channel 1 to the steering servo and channel 4 to a servo holding a micro camera. This setup has worked great for me. Just yesterday it's as if the 2 channels are getting crossed with the camera servo stuttering and jittering and moving when I move the steering wheel. The steering does the same. I did the following:
* redid the connector for the steering because the wires looked to start getting frayed and coming out of the connecor.
* switched channel 3 and 4
* put in new batteries into the radio / fully charged 2S lipo on the car
* in case this was a mix issue, I reset the model entirely.
Same issue.
I was using a new higher torque steering servo with an aluminum servo horn. The servo was getting caught so it could not turn its full extent. I believe this would cause the servo to draw higher current. Since everything is getting power through the receiver, could it have overloaded a BEC on the received or something? These are not cheap receivers so I will be highly annoyed if this is the case.
Same issue.
