setecastronomy
Yesterday my crawler moved its first steps but I had some problems with the electronics. My esc is a Novak xrs, largely used for crawlers.
There are 2 small leds on it and the red one is on in neutral, the green one is on when in full throttle while it blinks when in full reverse.
The weird behaviour is the following: applying full reverse throttle truck makes a small jump backward, then it stops. I thought it was due to radio interference and to the fact the antenna was sunk inside
the chassis but I noticed that the green led was blinking on the esc as during normal reverse functioning. Also applying full forward throttle there were problems because the truck moved with small
jumps as obeying a relentless full throttle-neutral sequence. Any idea ?
Perhaps it was due to low batteries, I doubt, but I will verify.
Thanks
Filippo
Thanks
Filippo
