RcBros LCC Dig Servo Mounts
RcBro
RcBros Hobbies
Vendor
Oregon
banner.jpg%7Eoriginal
LCC Low Center of Gravity Dig Mount
Its no doubt the Losi Comp Crawler is a great crawler, but sometimes that stock dig servo location is more harm then it is good, your either having issues with the linkage aligning correctly or the ball end is hitting your motor, not to mention it just simply sits to high leaving your center of gravity where you don't want it. Whatever the case if you can't count on your dig working 100% of the time, your never going to have that perfect run your looking for to take the win at your local comp.
We taken all these things into consideration by bringing your servo down low and backward accomplishing two things. Dropping your center of gravity and providing straight dig linkage eliminating all your past dig hassles. The mount simply replaces your stock electronics mount and allows your servo to fit snugly in between your driveshaft and upper and lower links.
The mount is designed for most mini servos on the market (see list below) featuring slideable servo mounts allowing you to shift your servo left to right to accommodate different setups. Weighing in at 10grams our mount equals the stock weight of the mount you are replacing.
Each mount includes a new 1" 4-40 set screw to lengthen your dig linkage and 4 3x12mm screws and 4 3mm nylon nuts to snuggly fasten your servo of choice. Also included are 4 4-40 screws and nylon nuts for securing the mount to the chassis.
Our mount has been tested with the following servos, please be sure to check your servo dimensions before installing.
Price at $14.99 plus shipping!! Order by Visiting HERE
Still available for purchase. We have since removed the side tapped holes, but we are including hardware to go straight through.
I have one of these in my LCC and I must say:
Wonderful quality and it mounts and works absolutely PERFECT "thumbsup"
Thanks guys!
