Burg314
I am having problems getting my rear drive shaft off. I have a yeti xl. How do I do this. Thank you for any responses
the two shafts should just slide in to one another. did you replace both parts? if one is twisted and you put a new part in to an old part that might be your prob.Is there an easier way to change the rear drive shaft? Seems like I had to almost break it to force the rear part of the shaft onto the front part of the shaft once I screwed the pieces onto the cv,s
That is the whole point of a driveshaft....is not to come apart at full stuff or droop or whatever cycle of your suspension...or you'd be droppin em.I only replaced one part. The other part is in good condition. The issue was that it didnt seem like they were far enough away from each other. I had both shaft pieces screwed to the cv's and I had to almost bend both of them to fit the two pieces together. I understand that you could go ahead and take the whole axle off and do it that way but was looking for a quicker easier way if their is a trick or something???
