A bit of an update: The rest of my parts finally showed up the other day.
The truck is now sitting on Gelande front hoops with 90mm shocks. 100mm rears .
I haven't modified the spring stack yet but I am sure I will once the rig can be run enough to determine what is needed.
The Onkuey lighting kit also showed up. Interesting gadget. I noticed right away that the leads will be to short for this truck ( as I built it ).
Due to the full interior and the fact that I mounted the interior tub to the chassis rather than the body , removing the body to service the battery was going to be a pain.
Add all of the lighting harness to the mix and it would have been a nightmare.
after a few days mulling this over I came up with a solution that works for me.
A tilt bed.
I won't be needing to remove the cab ( other than to service the engine bay ) which makes running the lighting harness for the cab much easier.
This also makes battery swaps a breeze.
The hinge is a built up affair from a standard 2" hinge found at Home Despot and some 3/4" x 20ga Angle iron. I added th stand off ( angle iron ) so that it could be mounted through the bed floor with countersunk screws.
Alignment was fun . Took several attempts to get it just right.
Now I can clean up all of my wiring and possibly start enjoying driving and fine tuning.
Valuable lesson learned : Never paint the body until your happy with the chassis , suspension and wiring.
This body will probably end up a basher. I will probably have to buy a new body kit for true scale fit and finish. Live and learn .
