Reverse transmission?
"Is it as easy as just flipping it?"
Pretty much. Just remove the four skid to side plate screws and lower the motor/trans assy. and turn it around. You will also have to flip the battery and rec/esc trays/braces and rearrange the wiring a bit. The drive shaft only slips back together when the 'U's at the axle and trans are oriented alike.
Thanks for the response. I flipped it last night. I had already moved esc and remover battery tray so it was really easy especially with axles out for cleaning. I had to reverse wires on motor though.
