Rod ends for threaded rod
Dubro Monster-Duty ball ends are some of the best you can buy for 6-32 threaded rod. We offer them in the replacement parts section of our website.
General dimensions as follows:
7/8" long to the center mounting eye.
Sized for 6-32 thread with body of end slightly larger than 1/4" dia.
Rod End is 1/8" thick (and will require conical washers to prevent binding)
http://www.crawfordperformanceengin...t=Replacement_Parts&pid=CPER-REP4&log_pid=yes
I like to use traxxas part # 1942 for my rod ends. They take a 4-40 with no problem or can be taped to take 6-32 and for around $5 for a package of 20 (16 long and 4 short).
I get mine from RC boyz off ebay. Quick shipping.
I used 8/32 threaded rod with Traxxas Jato rod ends.
They are tight going on,but they will fit without having
to drill the hole in the rod ends out.
Then I put steel brake tubing over the threaded rods,cut
to the lengths I needed.The brake tubing was a little loose on
the threaded rods,so I wrapped each end of the threaded rod with electrical tape until the slack was taken out and it centered the tubing
on the threaded rod.
