rocresq
the e sav gears appear hardened and seem to be slightly larger than the WK cause they fit nice and tight in the axle case with minimal shimming. try a set you wont look back. It is the only way Ill run WK axles
for reference, are these the E-savage gears everyone is talking about:
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXPCZ4&P=Z
If so, I think I'm going to order some, can't go wrong at $10 a pop.
oh, and the FLM axial lockers should work too right?
Alright cool. The problem is the design of the ring gear - it seems to have deeper teeth so on the "flat side" there are what I would describe as mini-teeth. In fact, you can see what I am talking about in the link I posted - that is the "flat side". I tried removing the washer from the pinion thinking that may have been keeping the ring gear from clearing the housing... no luck. I'll try moving all shims outside the ring gear, but yesterday I was fearful the ring gear would be too far into the pinion that way. Can't hurt to try tho! As much as I don't want to, I may have to Dremel the ring gear a bit as well. The housing actually bends slightly when I try to close it up and then the ring gear wears against the side... very hard to turn. I'll post up the results but I suggest everyone stay away from the gears I linked to earlier. Thanks again! "thumbsup"
It works! I took my Dremel to the backside of the ring gear and was still able to to keep some material at the valley of the gears - so far so good! :mrgreen:how'd all that end up working for ya?
I've got WK gears in the back of my Axial. Actually, it's a HD Axial 38T, and WK 13T. I've also got RS4 HS gears (36/14 - http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXJYM3&P=7) in the front of my Axial.
Soon, I'll try the E-Savage gears in back, as they seem to be a cheap steel gear alternative to crappy pot metal, or expensive machined steel HD Axials.
So I have all kinds of gears in mine. Granted it's an Axial, but I don't see why they wouldn't work in a WK?
