jthellfire911
Well after alot of research and help from toyzuki I too pulled the trigger on his full setup.
Parts list
Scx10 axles short xr10 front
Axial HD od front gears
Brass beef tubes front
Vp scale wraith knuckles
Vp clamping c hubs
Vp locker
Vp vvd hybrid universals scx shaft, wraith stub axles
Rear scx10 axle
Strc lockouts and hd shafts
Axial hd stock ratio gears
Holmes spool
Trans
Toyzuki lcg motor mount, and the case with hr 1 piece lower gear with integrated outputs
Full fast eddy bearings
Vp 1.9 omf wheels wrapped in gold klrs with klr foams
Proline scaler shocks front and rear
Custom links front and rear
Limit straps f/r
Mmp
Holmes puller pro stubby 540 3300kv
Hitec 7950 servo
Juggernaut servo winch
Heyok hv winch controller
Dx4s
Ccbec
Custom y harness to put 7.4v directly to the servo
All electronic besides the heyok winch controller have been waterproofed by Hellfire Waterproofing Systems.
Ford proline f250 honcho cab
Custom metal flat bed, sliders, f/r bumpers
Will have 3d Interior 4 seats,
Aluminum 4 seat interior cage
I'm shooting for right at 50 scale points with this build, and hopefully be under 7lbs rtr.
I moved the skid forward and ran into issues with my roc412 hitting the drivelines so I ordered the hh 540s puller pro. Then had an issue getting all of my links right since I moved the skid. Got all that figured out, made the Panhard ect. Put my home built servo winch in and the new locked up spool hit everything. So I ordered a juggernaut servo winch.
Parts list
Vp clamping c hubs
Vp locker
Rear scx10 axle
Holmes spool
Trans
Limit straps f/r
Mmp
Hitec 7950 servo
Dx4s
Ccbec
