Been doing some DIY mods while I wait on all my back order parts.
2g CG weights
They pivot on the screws to allow access or move CG forward
Cut from this clamp
Rubber spacers for better spring compression. I also put a little grease in the shock to dampen it a bit
Found these little rubber pads. Drilled a hole in the middle and slipped it above the spring
Wheel weights cut from this 1/2-inch EMT coupler
Found some little plastic washers to slip into the rear for a little extra weight. Total weight 8g
Couldn't use the plastic inserts here because of steering knuckle. Also had to cut the metal ring down to be flush with the rim because of the knuckle. Total weight 4.9g
Added some wire to the lights so I could mount them in the headlight position. I have to unplug them to open up, but I'm good with that. I like em
2g CG weights
Cut from this clamp
