ToyTundra
semi-scale Brushless tuber build
I've been telling my self i'll build a tuber for the last few years after selling a clod but I never got started. The MRC was what it took to get me going. My plan is a tuber that is a mix of scale and able to be somewhat competitive. I didn't buy the MRC kit as i wasn't going to use most of it. This proved to cost significantly more, but i did spring for upgrades like CVDs, metal rear lockouts, metal lockers, aluminum shocks, blue tires, etc. I should have bought the kit and parted out the transmission and electronics. Buying in $40-$60 spurts made me lose track. This is my first tuber, but i have brazed brass in the past for another project. Steel is significantly easier
Running gear:
MRC axles
5245 servo (frame mounted)
3 link + panhard front
4 link rear
sidewinder micro ESC
130 size brushless
planetary reduction
2s 1500mAh lipo
CCBEC or dimension engineering BEC, or maybe just the built in.
Airtronics RDS8000
I made the belly of the chassis pretty big, so i decided to run a mostly droop setup. Most of the running gear will be under the hood.
A 2s lipo will sit right behind the steering servo. The motor will be under the battery.
space is going to be tight for the panhard bar. Maybe a 4 link on front is in order. The black line on the floor pan is the tentative transfer case spot.
The cheap 3100kv motor and 104:1 reduction. I also bought a 6200Kv motor if i need more wheel speed. I used this gearbox with the stock brushed motor in a construction equipment project. It has tons of torque. The motor will never stall, but it does make the driveshafts spin on a non-keyed diff input shaft. After a successful test run i'll swap to a Park 400 inrunner, or do away with the weird driveline. I want to use a very small motor, but my second choice is a very large motor, like a standard sized outrunner.
A simple two gear transfer case. I decided to run a 1:1 ratio as wheel speed will be an issue. This case is supposed to have 3 gears (you can't see the upper one which was supposed to be the input) and a 1.5:1 ratio, but it s too tall for the chassis so I'll start over. Besides, my gear mesh was too loose.
Running gear:
MRC axles
4 link rear
130 size brushless
planetary reduction
2s 1500mAh lipo
Airtronics RDS8000
