DKNguyen
http://www.tribotix.com/Products/Robotis/Dynamixel/RX/RXCatalogue.htm
I need 4 servos (one per wheel) for steering my rig (the 25lbs one) and would get the RX-28 if I had enough money, but I don't. Would the RX-10 be enough you think? THe torque works out to be 139-136oz-in of torque depending on the voltage. THe RX-28's torque works out to be 393-523oz-in (after the converison from metric).
The torque of two RX-10s adds up to be the same as a HS-5955TG, except with the 5955 if one wheel has no resistance then all the extra steering torque goes to the other wheel. With two servos that are half as weak per wheel all the torque is stuck on the wheel it's connected to. THoughts?
