Servo reversed
pauljreese
Clermont
Hey guys quick question. Just built an Axial Yeti kit and installed the Tatic(Axial) servo. But, the servo works in reverse. Im using a Spectrum DX5R. Any thing you guys can think of?
You can reverse the transmitter, should be a button / switch if my memory is any good...
Sent from my Pixel using Tapatalk
Every TX has a reversing switch or menu option.
There is no "right" direction, depends on TX, servo and steering mechanism.
Look up thr manual if you can't find it.
Servo wiring retraction....I assumed you could do the same as with some baser electric motors apologies for the bad tid bit
If you can't find anything in the manuel or a button on the transmitter you could always reverse the leads on the servo...it'll make the servo work in reverse to what it does now...nothing saying it didn't come wired incorrectly
Don't do this, servos do not come wired incorrectly, and reversing the leads will only result in a servo that does not work, at all.
The DX5R has a menu for reversing the channel, but it can be a little difficult to find if you have never needed it. If you can't figure it out send me a PM.
Thank you. I finally found it
