Shocks
I'm running the RC4WD 'Ultimate Scale Shocks' 90mm on both ends. Be careful with any of the externally sprung GMade shocks though. I bought a set of the XD Aeration shocks and their diameter is massive. I couldn't fit them on the front as they fouled the lower arms, plus I needed to space out the top mount point as the shock top mounts wouldn't sit flush with the chassis due to the width of the shock. But pretty much any shocks that aren't those big GMade ones will work great and fit no problem.
Yep spot on they are mahusive, but the g-made transitions are slim and very good shocks indeed, plus can be run in droop.
Sweet. They come assembled, but crack them open and put a few drops of oil in there to keep the spring lubed up. Don't fill it up, it will just be rock hard, they are meant to be run dry. Grab some of their scale shock boots if you want it to look super scale.
I run RC4wD 100mm dual spring coilovers in the front. I have higher upper mounts and added a 5-7mm spacer behind it when installing them, for clearance.
I run them empty with a few drops of 80w in them.
I like being able to dial the spring rate in. Too low, you loose clearance, too high and no travel and flex.
Sent from my U20a
