iflylolo
Does any one have one since its hard to get one without having to pay for the whole truck?
your question confuses me.. are you looking for a part or asking for the parts number?
if looking for a part, you have a star so you can ask in the classifieds lol
For laughs I though I'd list what went into the making of the Hybrid:
(4) Rc4wd 2.2" Rox Lox w/included foam.
(4) Vanquish SLW V2's with Wide front and narrow rear hubs. Black with Silver rings.
(2) STRC Slash 4x4 Castor Blocks, Gunmetal
(2) STRC Slash 4x4 Steering knuckles, Gunmetal
(2) MIP HD Slash 4x4 CVD's
(2) MIP 6mm outputs
(2) Traxxas Upper links (Camber)
(2) Traxxas Steering links (Toe in/out)
(2) RPM Nitro Stampede Rear arms
(2) Traxxas XXL Big Bore shocks w/ Black springs
(1) bottle 40 wt shock oil
(1) bottle 100 wt shock oil
(1) Cut in half Slash 4x4 including shock tower, skid, diff housing, ring and pinion, hinge pins, hardware, etc.
(1) STRC Aluminum Slash 4x4 steering upgrade
(1) JR 9100T steering servo w/ aluminum arm
(1) sheet of Black Styrene
(1) Hitec 645mg Winch servo + bobbin spool
(1) Complete Summit TRansmission w/ spur gear
(2) MIP C-drive AX10 drivelines
(2) MIP 6mm outputs for above
(2) Tekin RS 10.5 Brushless System
(1) Tube of Silicone sealant
(1) J Concepts Bajr Body for a Slash
(2) sheets of clear lexan
(1) RPM 6 LED Lightbar
(1) 6 LED light harness
(2) Axial rear-view mirrors from scale detail tree
(2) CAstle BEC's
(1) Futaba 3003 Shift servo
(1) 3 Racing suspension Winch and control board
(2-3) Stick of 3/16 DOM steel tube
(1) stick of 1/8 solid rod
(2) Hot Racing AX10 shocks
(1) Kimborough servo saver
(1) complete Axial Axle
(2) Aluminum Axial lockouts
(2) Axial straight axles
(2) Hot Racing AX10 wideners
(1) New Era AX10 4 link mount
(1) brass pulley
(20) zip ties (+/-)
(10) bags of Traxxas 3mm hardware
(5) bags of 3mm nuts, lock and regular
(4) sticks of 1/4 .049 wall tubing for links
(2) sticks of 8/32 all thread for links
(1) Octura Teflon sleeving for links
(1) Can of Tamiya Metallic Red
(1) Can of TAmiya Gun Metal
(many) Decals
(1) Parsec Rally Interior
(1) sheet of 16 guage steel
(1) Maxamp 4200 11.1v Lipo
(1) Bit of screen soor material
(1) 32 pitch pinion
(1) Stick of 1/8 flat steel strip
I think that's it?
LOL.
pull up traxxas.com, go to the slash 4x4, then pull up the manual, and start writing down part numbers.
It is probably cheaper to buy a "roller" on ebay and selling the parts you don't end up using though.
ok,
ive done several of these rigs now & figiured out mostly whats needed & what works "thumbsup""thumbsup"
this list is just for the front end, trans & rear end,
there will be other things needed (shocks, wheels, tires, motor, chassis & so no)
slash 4x4/4400 list & parts #s
complete slash 4X4 front diff & case ($15.00 to $25.00 new on E Bay)
TRA5381X Differential Spool Revo EMX $12.00 (needs 6mm MIP drive cups) or barzzar hobbies slash 4x4 locker $8.00
TRA6830 Bulkhead front $5.69
TRA6823 Bulkhead Tie Bars Front $6.49
TRX6834 hing pins $6.00
TRA6837 Steering Blocks Left & Right $4.59
TRA3655X Suspension Arms Left & Right $8.99
TRA6839 Shock Tower Front $5.49
TRA6832X Traxxas Caster Blocks Aluminum
TRA2728 - 5x8 bearnings x4 $8.00
TRA5116 - 5X11 bearnings X2 $8.00
TRA5119 - 10X15 bearnings X2 $8.00
TRA3967 3X10 CSS screw $3.00
TRA3624X 3x12 CCS screw $3.00
SPTST6845 STRC Alum Steering Bellcrank Set $29.99 (a must have part)
MIP10132 MIP Slash 4x4 H/D front shafts $48.99 (a must have part)
MIP08101 - MIP ax/10 shafts (one only & a must have part)
TRA5525 jato ball ends X16 (large ends) $16.00
AX30488 compelete axial AX/10 rear axle - straight axle kit, H/D r/p, H/D locker(must have)
SPTST1654 STRC alum hex hub $15.00
compelete summit 2 speed transmishion ($45.00 to $100.00 new on E bay)
optional alum parts:
TRA6832X Traxxas Caster Blocks Aluminum Left & Right $34.99
TRA6837X Steering Blocks Aluminum Left & Right Slash 4x4 $24.99
SPTST6839B STRC Aluminum HD Front Shock Tower $20.00
ok,
