valheru
Since there is no dedicated “Vaterra Slickrock” or “Mini Scale Rig” (1:18 to 1:16) sub-forum and this vehicle is a 1:18 crawler equipped with 1.9 tires, I guess that the “1.9 Scale Rigs“ sub-forum is a good a place to post my build as any other.
If not, than I am sorry in advance.
To the big despair on my wife…
ror
in December 2016 I picked up RC #3 from my LHS, it was their demo Vaterra Slickrock 1/18-Scale 4WD Rock Crawler.
Here it is being welcomed by the rest of the family. :mrgreen:
It came with an upgraded ESC since the original one died under their watch otherwise, everything else was bone stock.
Upon reading a bit on my new acquisition, the first thing I did was relocate the battery and the electronics as far forward as I could inside the chassis, flip the transmission 180 degrees.
Quickly realizing that the turning radius was “slightly impaired”, I managed to source all the parts from the Losi MRC Pro to go CVD in front with aluminium carrier, spindles, lower links and threaded shocks with a choice of springs. This made a big improvement on the turning abilities to the point that the tires could no rub against the lower links, giving the vehicle about 45 degrees of turning angle.
Not too long after upgrading the front steering, the stock servo started to act up :roll:, therefore I went big with a Castle 10A BEC, Savox SC-1251MG digital servo running at maximum voltage of 6V, a Hot Racing aluminium horn and I made the steering linkages out of 5/32” steel and Traxxas ball ends.
One thing that bothered me since day one with the Slickrock was the un-Godly noise the transmission made under operation. Therefore I ordered the complete transmission aluminium upgrade kit from Hot Racing; the housing and all the gears in an attempt to quiet the little guy down.
The transmission aluminium upgrade didn’t really help, therefore the issue must lie somewhere else.
After taking everything apart again and reading some more, I realized that at the size the factory specified 48 pitch pinion gear needs to be, the gear profile was in fact not shaped properly to match any 48P spur gear, factory or after-market.
I then ordered some 0.5Mod pinion gears to try out with the stock 48P spur and magic, 60%+ of the gear noise is gone!
*** Sorry no photos of this ***
One thing that the Slickrock suffers from immensely is torque twist; driving straight on level ground the whole body tilts a good 30 degrees to one side and this really annoyed me including a tendency of the front springs to bind because of their pronounce tilt angle, even with the upgraded shocks with Tin coated shafts.
Therefore I decided to make a front shock mounting frame to relocate the top of the shock that they could be mounted more vertically. It’s made out of 1/4” steel and utilizing the factory shock upper mounting points and 2 of the front hood panel mounting points.
I also tested every combination of springs I had, from the supper soft to the hard, and shock oil, from 15 to 100, in an attempt to get rid of the torque twist. Where the torque twist was reduced to a point of being satisfactory, the suspension flex was being compromised because of the lack of mass of the vehicle to make it move properly.
So I decided to make a rear sway bar using the Vaterra Twin Hammers rear sway bar kit as a base.
I then bought a variety of spring steel rods from my LHS and bent my own sway bars to match the space and suspension travel available on the Slickrock. The upper bar is one I made, the lower is the smallest bar from the Twin Hammers kit.
A small length of 4-40 all-thread rod, some 1/16 Traxxas shock ends, a piece of micro tubing to act as a bushing and a few zip-ties, and it performs like it was designed by Vaterra.
While I was working on the rear sway bar, my RC4WD order of 1.9 Raceline bead lock wheels, +6mm offset hubs and 1.9 X2SS compound Mud Slingers arrived!
D 8)
D 8)
