slim_chance
[I know I did a thread introducing my ax10 scorpion but I have done quite a bit to it. I have only done a very short test in the front yard. I have some torq twist issues to deal with before I try hard stuff.
Updated specs. Newer pics soon.
Hpi beetle baja bug body hacked off fenders
Metal tube steering links - Changed to Axial aluminum links
Axial 30º high clearance lower links - changed high clearance rear straight fronts
Aluminum hubs and knuckles
55t axial motor not pictured ran the 27t during the test
1/2" whe wideners now 11" wide - removed
Losi spektrum radio set
Xl5 esc - changed to tekin 610-G. No drag brake but it works awesomely with LVA
Traxxas 2070 servo- changed to Hightech Hs646wp
Stock shocks set for semi droop all internal springs (possible culprit in the tt case) Changed to non droop internal springs.
Panther Leopard tires (might be too heavy in the front I got them assembled and didnt weigh them another possible culprit in the tt case). Changed to lighter weights HB Sedonas with "aired down" foams
Strc aluminum skid flipped upside down and mirrored with inboard links. Weird but it works great
3s 2200 mah lipo
Things to come
Tekin fxr esc- not really worried about it anymore
Traxxas drive shafts- changed to aluminum when funds permit
35t open bell motor or possibly traxxas monster titan 550 I have the latter - changed sticking with 55t once axial 55t burns out. I have 2 spare novak fifty-fives
4 aluminum uppers
Putting the red cat wheels back on with the panthers- see current specs
Axial 2.2 wheel weight inserts- Used stick on weights
Aluminum skid-added.
Ax10 dig. - changed going with od ud gears.
Moving the tops of the shocks back to the inside- done
Lipo! I have assorted 2s and 3s. -done
I have a Lva ordered so I can run lipo on one of my old esc's that have a 10+ cell cap.- done
CC BEC just needs to solder in.
I think there was more but I forgot. Open to comments and suggestions
On with the pics
3s 2200 mah lipo
Things to come
4 aluminum uppers
On with the pics
