So I just got a twin hammers! Help please
Mikael
Canada
So I just got a used twin hammers with some really good electronics.
Anyways when I got it and paired the controller it was working (turning, driving) at that time I didn't have the wheels on so when I put them on and I try to drive the car it makes a kind of gear grinding noise. When I press the trigger the gears spin but it's not moving the drive shaft. When I roll the drive shaft with my fingers the wheels move. Also the pinion gear is a bit rusty. Any ideas? It makes a "Whiiir" noise.
Here are some pics
Mikael_m29's Library | Photobucket
Have you checked-
for binding
the slipper
the motor turning
Have you removed the spur gear cover?
have you disconnected the shift servo and tried to manually engage high and low gear.
Process of elimination "thumbsup"
