So many metal joining methods How to decide . Stay-Brite Silver solder
toy4crawlin
Campbell, CA 4 hrs 2Rubicon !
Is there a Expert that can tell us How strong these are , how to decide what to use ??
I have both of these to use but the stay-brite is so much easier to use.
Stay brite silver solder
saftey silv 56, Brazing with mapp gas
Any others ?
Thanks
i use UNIWELD. UNI-1000 flux and UNI-1056 silver solder, brazes awesome. its the same pretty much the same stuff as harris.
mapp vs butane dos'nt matter with the strength. diff gasses just heat up the material to be "welded" faster than others. I'm actualy not sure about butane compared to mapp, I use mapp and it works fine....
:?: so basically you would use Mapp gas because the silve content is higher therefore it needs more heat
Why use silv 56 with mapp gas which costs more then just a butane torch and silver solder such as stay-brite or ultragrip :?:
You wanna get in and out with the heat as quick as possible. Silver solder flows at a lower temperature than silver brazing alloys. Silver solder is just as good, its just used where heating a component (like a refrigeration valve) to join to copper at lower temperatures, where brazing would ruin parts inside the valve.
