Pushjerk
Picked these up on impulse, for no reason other than curiosity, and have just rolled with it. I don't feel the 10.2 requires the steering improvement that this mod comes with as did the V1. As for the wider stance, from the running I've done with the rig (which is far less than many if you dudes have), I have not felt that it truly needs any added stability. So again, this has been a "why not?" sorta project.
The mod is not the simplest, required some brain storming, but is by no means out of reach of all the talent I've seen on this forum.
Beef Tubes states that these are "Stock XR" width. So all of the normal SCX10 Wide XR Mod components should jive. I have never done this mod on the V1, But I suspect that this new V2 setup from Beef Tubes might be just a tad wider.
I went with a VP Wraith Stage One kit for the Knuckles, Chubs and Lockouts.
For the Front , the Axial XR Universals (AX30563) did the trick, though the flat portions on the inboard side of the axles that insert into the locker were too short, and required some extension outboard to fully fit into the locker, grinding about 1/8" up the shaft on both sides.
Next problem to solve was the axle panhard mount. I'm currently trying a VP Wraith Panhard setup. It's pretty big, but the geometry might jive with the other Wraith parts. It clamps to a Wraith axle, so the required OD of the axle is much bigger than the AR44 - a quick custom brass clamping ring to go between then Beef Tube and the PH mount, and it's stuck good. This requires disassembly/removal of the Beef Tube from the axle housing.
For the Rear, as rear XR10 Axles (AX30758 ) are a myth nowadays, I had to look else where. Custom shafts were not really in my budget, so for less than $40 for two pairs, I got some Wraith Rear Straight Axles (AX30776), cut the long ones to length, and ground the inserts for the locker - the job lacks some perfection in looks and absolute centering, but I think it'll do the trick for now.
Here's where the suspected slight extra width of the Beef Tubes 10.2 axle housing became important. The Wide XR Mod for the V1 calls for either the 110mm shaft or the 117mm shaft from the Axial set, depending on the gear you choose. My math led me to believe even the 117mm would be too short, leaving almost a 10mm gap between the shafts inside the locker, with very little for the locker to bite.
I cut my shafts to about 121mm, and have plenty of shaft inserted into that b*tch to work (pistachio).
So, how does it look? Too wide? Just right? I think it's pretty ok for the Cherokee body. For others, we'll see.
Just need to fab up some links for the front and we'll hit the rocks.
