Something new for the garage
JasonInAugusta
06 Super National Champ
Moderator
Stark Industries Bar and Grill
Had a guy (Young_Version) ask me to make some house vents for him and while making them I decided I needed a new router table. The table I've been using is a simple thing made from MDF that we used at the car audio shop. It was a basic thing. No dust collection built in, no miter track or anything, just a MDF frame with a pocket for a JessEm router lift and an Alucobond top surface.
It was fine at the shop because it was in a dedicated wood shop and dust wasn't a big concern. BUT...at home it makes a big fawkin' mess. And it was fawkin' good at it. :ror:
I researched different router table ideas/plans and didn't see anything that made sense to me. Seems like everyone builds a router table for nothing but routing. Whether it's a freestanding table or an extension on a table saw, the only purpose they serve is for routing. They're not big enough to be used for anything when you're not powering up the router. I wanted something that would allow me to have the ability to rout anything I'd want, but when it wasn't being used as a router would still serve a purpose.
Like, say...a workbench.
With the general idea in my head I went to Woodcraft to get some Incra miter and T-Tracks. Wanted to go ahead and get the router fence but they didn't have it. While there I saw they had a sale on 1 1/2" x 27" x 60" birch workbench tops. Grabbed one of those as well.
A few pics.
Special Agent came over and, while BSing, I cut a slot for the miter track and the pocket for the router lift.
Rubbed some Minwax Natural stain on it.
Then I realized I put the miter slot where the T-Track was supposed to go.:roll: Shouldn't have been BSing so much. :lol:
Cut a new slot for the miter track (in the proper location this time) and widened and extended the slot for the T-Track. With the new top laying on the old router table the work height is 38 3/4" which is good for me.
Picked up a couple of sheets of 3/4" maple plywood - couldn't get birch, but that's OK. I figure the base cabinet will be 56" wide and 24-25" deep. Plan on four 2 1/2" swivel casters. The two fronts will have dual locking brakes.
Spent some time getting the basic framework drawn up and had a buddy come over to have some electrical work done. Did that and got him to hold one of of a sheet of plywood while I cut the back out with a 18V DeWalt. Used a piece of 3/16" for a fence/guide.
So the back is cut out, need to cut the two sides and the main shelves. I figure once I get the main assembly dry fit I'll have an easier time determining exactly what size drawers I want in that small section on the top right.
Anyway, here's a sketch of the general idea. Sort of to scale (1" = 1') for overall width/length.
Got the back and sides cut out from the first sheet of ply.
Put the new top to use already. :D
Sides are 23 1/2" x 33 7/8"
Back is 52 1/2" x 33 7/8"
Got the main portion of the cabinet dry fit. Now to sort out partitions and drawers.
iPhone camera distorted things a bit (top looks like it's sagging, bottom shelf is bowed up, middle shelf is straight) but everything is straight.
I really wish I had brought my table saw with me when we moved but I decided against it. :roll:
I'm unsure what I want to do with the base as far as finishing it. I used Minwax "natural" stain on the birch top and thought about using it on the base, but I'm unsure. I've built the base out of maple ply and all of the rails and stiles will be maple. Drawer fronts will also be maple.
Wife loves it. We were in town and I was looking at drawer slides. She said "It has to have soft-close slides." :D
I spent a little time finalizing partitions for everything. It's all still dry fit together.
Up top, on the left, will be three 33 1/2" wide drawers that will be 21" deep.
Top right will be some small drawers for router bits and wrenches. Above them will be a hidden area for power cable that will keep them out of the drawers.
Bottom section will have two drawers per side, 25" overall width, 21" deep.
Also picked up some 2 1/2" dust collection items so I can make a T from the router chamber to the fence.
Started work on the inside of the router chamber so dust doesn't collect in the corners. Got late here and I didn't cut the back wall (neighbors). Kept the router chamber as compact as possible in an effort to reduce the volume of air the Shop-Vac has to pull from the chamber. This also maximizes drawer space.
I wanted my on/off switch for the router and vac up front but didn't want the cables laying all over. The solution was to build a partition above and behind the small drawers.
As you can see from the above pic, I also made drawers for the 1/4" and 1/2" shank router bits.
Here's the 1/4" drawer. Need to drill the 1/2" drawer and assemble it.
The work area. No table saw so I'm using that Kreg Rip-Cut. Not a huge fan, but it's getting the job done.
Today I didn't get much done, but I managed to get the maple cut for the rails, stiles, and toe kick. They're cut to rough length right now and a hair (1/32") over finished width.
Also managed to get one set of drawer slides installed tonight. I wanted to get these three installed during dry fit (all of the panels are assembled with Kreg pocket hole screws) so I can make sure they work before everything is glued up. It's a PITA working in that small opening. I should get the rest of the small drawers installed tomorrow then it'll be time to blow it apart and start gluing it up.
nice. everything ive ever seen you create is just amazeballs. "thumbsup"
jia, what do you do for a living if you dont mind me asking?
That's some nice woodwork! "thumbsup"
-Corrupt
Amazing work Jason, always great to see your projects.
I like the drawer design and fit.
Nice clean work and clean drawing as well.
Thanks, guys.
wings_of_fire, that drawing was just something to force me to really think about how it's all going to fit together more than anything. I scaled the outer dimensions but eyeballed the rest.
Over the years I've done a bit of everything. Lived/worked on a horse farm, pizza joint, cabinet shop, car audio, secure communications repair in the military, instructor/technical writer, civilian teacher, magazine editor, car audio again...
Lately I stay home and avoid dealing with people. :lol: With the wife's work schedule and the kids' school schedule it's pretty hectic.
That is awesome! Want to come over and build me some work benches? PWEEEEEESEEEEEEE? :ror:
:lmao:
Not the first time someone has asked that question.
Thanks, guys.
C*H*U*D, I really don't understand people doing it differently. Why not make it more functional?
Wife wants me to build a patio table with a tile top. I told her was wasn't going to build "just a patio table". Told her it needed to have more function than that.
When I get this router bench wrapped up I'll start drawing up the table.
I bet every time JIA moves the crew walks into the garage and says "This is place is awesome!" followed by "Oh sh%t we have to move all this stuff?:lmao:
:lol:
During our last move they came through the house and said "Yeah, we can get this done in a day. What's in the garage?"
Took them too the garage and opened the door.
"Whoa. Um...yeah. Three days. Nice setup!" :lol:
We got the crew whatever they wanted for lunch each day, kept them stocked with water and Gatorade, and I even cooked up some pulled pork for the final day. So they treated us well. "thumbsup"
We didn't bring everything with us on the last move and what stuff we did bring we've thinned out since. Smaller house, smaller garage. We've given away a couch, shelving, redundant tools, and a good bit of other stuff.
The next move will be much easier. "thumbsup"
Grabbed 6-32 Tee nuts for the small drawers. These are much better for the 1/4" MDF sides than the stock screws. Stock screws are junk for pretty much any use.
Mounted the top drawer.
Needed to go get a belt for the belt sander. Ace Hardware had everything the store at 75% off. I grabbed 26 drawer pulls, 28" x 30" acrylic sheet, some hinges, and a couple of other things. $37. :mrgreen:
Also got the back wall of the router chamber built and in place. No corners with dead air so dust can collect.
Blew it apart, glued and re-assembled it all.
Bottom partition is in, 3/4" maple for rails and stiles attached, and the front, left, and back edges (top and bottom) were hit with the 1/4" round-over bit. Also made the door frame for the router chamber.
