After TWELVE successful Spaz Stix paint jobs - including four Color-Shifting Paint Jobs.... There IS a key to this.
First, there's NO real good instructions on how to use it! I used to Paint 1:1 Cars, and used a few of those tricks. I found out that Spaz Stix is a combination of Polyurethane and Lacquer Polymers.
So I prepped the Body accordingly.
I
Wet Sanded the entire inside of the Body (Except of COURSE, the Windows). Ruined it?? NOPE! Since the OUTSIDE of the Lexan acts like an outer Clearcoat, almost ANYTHING that you do to the inside, will make NO difference in the finish!! ;-)
Use 1000-1200 grit sandpaper, at a sink, with constantly running water. This is an extreme wet sanding!! Try to get in every little seam and detail.
Then, still with warm water, go over it again with a fine Scotch-Brite pad, with a GOOD Dish Soap (but not one of those "fu fu" heavy scented Soaps!!).
Then, thoroughly rinse with the hottest water that your hands can stand.
Let AIR DRY. Don't touch the inside with ANYTHING.
Then....... Paint just like you would Paint anything else - just NOT under about 65 degrees F. (You shouldn't Spray Paint anything under that temperature anyway!! It's not good for anything, except maybe Acrylics.
IT WILL WORK like the! No, it's not for everyone..... If you don't want to do the extra work, that's always your choice. But if you want a Paint Job that gets ooos and aaas, THIS is how to do it.
Frankly, I've always said that Spaz Stix should come with a disclaimer! It's NOT a "spray and go" Paint. However, for those up to the challenge, it can be show stopping!!
I do NOT work for Company. I just don't like when ANY Product is the subject of scuttlebutt and opinions, without knowing the whole story. Now there are some really good Painters on this Forum, and some great ones too!!! It's not THEIR fault that a product came out, that needs some special handling - an didn't give ANY information about any different procedures....
These people are just trying to feed their Families, like everyone else!
NO! They just put it out there and sold to experienced Modelers, who rightfully assumed that they knew how use it - EXACTLY like all the other paints they've used. Which isn't the case with this.
I sincerely hope this helps someone.
