Hey All,
Im just finishing up my first ever crawler build on an Axial XR10 with Tekkin FXR's, Spektrum AR1000e Rx and a Spektrum DX6i Tx (originally Mode 1, but i did the mode hack to set it to mode 2 - no hardware changes).
I've managed to bind my Rx, configure the ESC's and setup basic mixing. I've set it up so the left stick (throttle) controls the rear esc, right stick (elevator) controls the front esc, right stick (aileron) controls the servo.
Those of you who have the DX6i (possibly applies to other Spektrum Tx's) know that you cant have the Throttle as a slave in the mix, so I've set Throttle as the master, with elevator as the slave, set constantly on, U/D 100% with trim inh.
The mixing works perfectly, however, I've found that you can stick control the front esc independently with the right stick whilst using the right stick to steer - this is undesirable because unless you have perfect control and accuracy it causes the front set of wheels to drag or go in reverse - hoping that makes sense.
Now im wondering if anyone knows how to disable the control of the ESC with the right stick leaving F/R to be controlled in the left stick when mixing is enabled, leaving just the steering in the right stick?
Im sure theres a way to hack the wiring and feed both ESC's into the Rx throttle slot, but I'm sure that its not recommended and would possibly cause problems.
Anyways, I'm looking forward to advice/suggestions.
Thanks.
Thanks.
