hoghead5150
ok put on strc aluminum c hubs and knuckles. got the aluminum link upgrade also. the problem is steering. this thing has the turning radius of a surburban towing an airstream!!!
how do you get a decent amount of steering angle in these things? i know i need a new servo, the stock one sucks, but even with the stock one it will turn sharp enough that the knuckles tie rod arm almost hits the screw head on the c hub, and the other tire will rub the lower suspension link.
i've searched here for 3 hours tonite, and really can't find much help on this. i've seen beef tubes ( can you still get these?) and talk of inboarding the links, but that won't stop the tie rod arm from hitting the c hub screws will it?
