Goal is the have a top performing car under 3lbs with battery and proper front weight bias.
I have wanted to build this car since I got my first pair of prototype Superlite’s back in 2012ish. I got that car down to 3lbs 3oz but that was with almost zero knuckle weight. That parts just didn’t exist then to get a car that light and work. Things have changed….
A build like this requires weighing every part as every gram counts.
Built list-
OG all Delrin Superlite’s (still the lightest axles
Custom DJM Skeena chassis
Custom DMJ ultralite wheels
Scx10 shocks with ultralite add-ons
Dlux “Team” Stumpys
Shift RC GT3s LP servo
Hiper Apex escs
Aluminum rod end balls
7075 lower links
Custom carbon upper links
Al and TI hardware
Modern SAF gears
Narrowed OG Voodoods front
RC4WD pins rear
CI foam
Built list-
Dlux “Team” Stumpys
Hiper Apex escs
7075 lower links
Al and TI hardware
Modern SAF gears
RC4WD pins rear
CI foam
