STUMPY(dually)
jeepguy
crescent city
heres what i have so far.
low gear mod/stock servo mod(from my first nylint),axle shave/rear axle straight up/
& dually conversion in rear(for now)
heres a couple pics. it will go straight to a wall & climb till it flips over without spinning or anything. lots of traction..
got the front duals built & on.
all parts are from my 2 nylints. the bolts are from the gear boxes after i did the extra gear mod. no glue so i can take them apart. it has alot of traction with 8 tires now.
& i was amazed that it has the same amount of steering power.
i'll try & get some pics. its really easy.
you use 2 inside rims,1 outside rim, 2 bolts
from gear case/or any bolt about the right size.
leave 2 screws on 1 wheel.
put other wheel against 1st wheel with no outside rim half with inside of rim pointing out.
drill the other 2 holes in 1st wheel out.
then screw together
