rc crawler boy
I am having trouble piecing my new transmission together. I am not sure the order of how the top shaft compontents are suppose to go in. So far i am using the stock spacer between the motor plate and trans case. So i put the shaft in then i use the small plastic spacer then the 2 bearings but with all 3 of those i am not able to fit the spur pin in. Then it came with this and i am not sure what it does cause harleys instructions dont include it.
Do you use the two bearings they give you as spacers?
I am using a ax10 case and the ultimate motor plate.
