Swivel Frame Power Wagon Build
The R2 is just mounted by making a bracket from some aluminum angle iron I had laying around...
Thought I would share a few pictures of a little trail ride I did over the holiday weekend on my family land up in Michigan. I got down to the lake and realized I didn't bring my camera :-(, so all I got was a few pictures with my cell phone.
Enjoy!
That's one of the coolest rigs in here.
And the fact that you did it woth so many stock Hi-Lift parts makes it that much cooler "thumbsup"
This is by far the best original idea I have ever seen. What a job! It works just like the 1:1 version, to the tee. Great Job!!
I wanted to thank you guys for all your comments, and give an update on a couple changes I've made. I've been running it quite a bit lately, and it's been doing great.
One of the changes is that I am just running a limiting strap on the swivel now. The shock worked great, but it's just too crowded on this chassis, and I swapped it out to make it easier to mount the ESC. The limiting strap does a fine job of making sure the swivel doesn't swivel too far, and the dampening effect wasn't that important to it's performance.
The next change is addition of a full size spare in the bed, along with a bunch of feed sacks I picked up at Hobby Lobby for $0.99. It needed a load, and it helps hide some of the huge ugly flat lexan bed.
I just love the "flex" shots on this truck:
"thumbsup""thumbsup""thumbsup"
Nice to see it's still alive "thumbsup"
Are you sure there's no room for a dropped (lexan) bed ?
I probably could, but the battery holder is under the bed right now. I'd just need to relocate the battery lower so I could drop the bed. I probably should do that anyway to lower the CG.
Very nice. Found this thread back in the Spring when I searched for PW builds. No idea a swivel frame even existed. Built my frame following yours. Built a worm-drive winch for the front. Scratch building the body. Bed is almost done in styrene. Was going to do the cab in styrene also but preliminary tests have shown heat-forming styrene to be tricky.
Keep up the great work.
Just found this, looked through the hole 8 pages, what a kick a$$ truck. Just too kool."thumbsup"
Good job my friend.........here in venezuela is´s verry dificult find good pices to do jobs like that.
Saludos from Venezuela.
Whoah ok sweet...finally get to see this swivel frame idea in action...might need to make one of these sometime!!!
Matt
