congratz to the win, good job man "thumbsup"
Thanks for the videos, some sick lines :shock:
Thanks. Finished 2nd at last weekend's NWARC comp. There were only 3 of us but the other two drivers are really good! Truck worked really well. I lost by 1 point.
I can't leave "good enough" alone so I have been doing some experimenting with squat and anti-squat this week and weights.
I added the rear D-Lux axle mount to see if anymore upper link changes needed to be done. After several battery packs of testing, the rear uppers ended up back at the same location before I put the new mount on. :ror:
I have another mount for the front as well.
For the front, I did some experimenting as well. I dropped the front upper down a hole to the lowest chassis hole. Was one up from that. Ran that for a bit and the truck was getting tipsy up front so I took 1.6oz of total weight off the knuckle weights. Calmed it back down. Just leaves the base knuckle weights. Wish there was a way to move them out further on the axle!
As of one 450mah pack, the truck handles just as well as it did with the extra 1.6oz up front. So to me, I think I learned what I kinda always knew. :ror: Lower the uppers on the chassis you can remove weight or vise versus. Chicken or the egg. It's a weight to squat ratio thing, I have come to conclude.
Truck is 4lbs 11.5oz with khaos-rovers. Narrowed Khaos-Rovers are in the mail.
Again, this is just experimenting with setups. Might workout might not. Need to put some more packs on my test lines to see for sure.
And used Decim8 app to skew a couple of the truck. Just messing around. Pretty cool IPhone APP for $0.99.
21 digital pixel alterations that can be added to one another and layered.
