TwistedCreations
Colt Python/SR9c
Well I got bored and decided to screw off for awhile :mrgreen:
So here you will find A TON of info about mods done to the trucks of the RCC community.Also There is listed some questions that are time and time again asked.If you ask a question and it is covered in this thread,we know you didn't take the time to do your homework.. So why should we take our time to help you? You need to learn to help yourself first, unless your just a spoiled little brat that was born with a silver spoon in your mouth :roll:
Anyway -
What truck is best for me?
It all depends on what YOU want. There are shafty trucks ( those that have a transmission and driveshafts ) and then there are clods ( which don't have the trans). Everything is basically located on the axles of the Clod, which seem to give it a better fight in comps.The clod,along with the TCS Extreme chassis ( The Stick ) is a very great combo for comps.It keeps it lightweight and the CoG (center of gravity) very low. The shafty trucks such as a TXT,Maxx,TLT,etc are a bit more to build, since you have more components to add and the "torque twist" to fight from having driveshafts.People say the shafty trucks are more "real" to build.. so once again, it is all up to YOU as to what you want to do.If your not into the big trucks, you can go with a 2.2 truck such as the TLT or you could put 2.2 rims on any other truck and make it smaller. The reason it is considered a 2.2 is due to the size of the rims.
Now here are some stickies that have been posted in each section for the truck.After reading these, they should have helped you decide as to which way you want to go.
Clods
TXT
Maxx
TLT
Also, each section has a "members rides" section in there to get ideas aswell.
What tire is best for my truck?
Very simple answer- we can't tell you. It all depends on the following- your terrain,your truck,your setup of your truck,the weight of your truck,etc.etc. The best bet is to ask others in your area as to what the run and find is the best. So don't make a post asking for people in the Oregon area as to what they like, PM people. Some of the popular tires are the Moabs,LST's,Giant tracs. More of the tires and sizes can be found here Tires
What can I do to my Nitro to have a good crawler?
Sell the thing!!! Nitro sucks for crawling. Those 2 things don't even go together in a sentence. Don't even mention that freaggin Revo video that Traxxas has :roll: unless you convert your nitro over to electric,you are wasting your time
Are MM motors,the TF truck,among other things discontinued since TowerHobbies lists them as that?
NO! Just because Tower lists them as discontinued, doesn't mean they are. Once again,you should use that search button..Tower basically quit carrying Kyosho parts. You can try www.rc4wd.com or you can go with lathe motors
what is a GD600?
It is a gear reduction unit used from planes. you can get them here http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXSL79&P=ML
You will need to have the output shaft turned down to 1/8" to fit the pinions or if you run big enough pinions,drill them out.
ohh well look what i found using the search for 30 seconds :mrgreen:
http://www.rccrawler.com/forum/showthread.php?t=18505&highlight=GD600
http://www.rccrawler.com/forum/showthread.php?t=6390&highlight=GD600
Now i know that most members have probably never seen this post that Bender had taken so much time in doing, so it is copy and pasted from his post. It is alot of links for the tips and cheap tricks guide.
Painting the body (opinions on brands).
http://www.rccrawler.com/forum/showthread.php?t=2836&highlight=painting+body
Tips on painting bodies (correct way).
http://www.rccrawler.com/forum/showthread.php?t=845&highlight=tips+painting+bodies
Stripping paint from lexan.
http://www.rccrawler.com/forum/showthread.php?t=4266&highlight=stripping+paint+lexan
Lexan body work.
http://www.rccrawler.com/forum/showthread.php?t=4194&highlight=lexan+body+work
Ultimate tire foams.
http://www.rccrawler.com/forum/showthread.php?t=3734&highlight=ultimate+tire+foams
Removing glued tires.
http://www.rccrawler.com/forum/showthread.php?t=1590&highlight=removing+glued+tires
Cheap plastic rod end slop fix.
http://www.rccrawler.com/forum/showthread.php?t=3843&highlight=slop
BFT rod end part number and price.
http://www.rccrawler.com/forum/showthread.php?t=3155&highlight=part+number
Traxxas rod end part number.
http://www.rccrawler.com/forum/showthread.php?t=3076&highlight=part+number
Cheap metal rod end bible.
http://www.rccrawler.com/forum/showthread.php?t=1003&highlight=part+number
Monster plastic ball ends.
http://www.rccrawler.com/forum/showthread.php?t=2433&highlight=plastic+ball+ends
Gear ratio equations and chart.
http://www.rccrawler.com/forum/showthread.php?t=2406&highlight=gear+ratio+chart
Balancing weight.
http://www.rccrawler.com/forum/showthread.php?t=2230&highlight=balancing+weight
Find your center of gravity and balance.
http://www.rccrawler.com/forum/showthread.php?t=3201&highlight=gravity+balance
Adjusting anti-squat?
http://www.rccrawler.com/forum/showthread.php?t=1263&highlight=anti+squat
Torque twist (how to fight it).
http://www.rccrawler.com/forum/showthread.php?t=2254&highlight=torque+twist
Revo shafts (how to install).
http://www.rccrawler.com/forum/showthread.php?t=5371
4 Link 101. (proper set-up tips)
http://www.rccrawler.com/forum/showthread.php?t=2169&highlight=4-link
How to figure link length.
http://www.rccrawler.com/forum/showthread.php?t=18015
Making links.
http://www.rccrawler.com/forum/showthread.php?t=1588&highlight=making+links
Best way to link mount shocks.
http://www.rccrawler.com/forum/showthread.php?t=1404&highlight=link+mount+shocks
How do I stop my link clamps from sliding?
http://www.rccrawler.com/forum/showthread.php?t=1646&highlight=clamp+sliding
How do I fishmouth brakeline?
http://www.rccrawler.com/forum/showthread.php?t=2958&highlight=fishmouth+brakeline
Harris safety silver-56 (where to buy).
http://www.rccrawler.com/forum/showthread.php?t=3439&highlight=harris+safety-silv
Brazing stainless?
http://www.rccrawler.com/forum/showthread.php?t=3410&highlight=brazing+stainless
Bending aluminium.
http://www.rccrawler.com/forum/showthread.php?t=1836
Cutting aluminium.
http://www.rccrawler.com/forum/showthread.php?t=6170
GD-600 (how to install).
http://www.rccrawler.com/forum/showthread.php?t=1495&highlight=gd600
645mg turned into winch.
http://www.rccrawler.com/forum/showthread.php?t=17970
http://www.rccrawler.com/forum/showthread.php?t=1695&highlight=645mg+winch
Correct part # for pinions.
http://www.rccrawler.com/forum/showthread.php?t=1557
Servo saver or not.
http://www.rccrawler.com/forum/showthread.php?t=1352&highlight=servo+saver
Truck problems (fixing glitching).
http://www.rccrawler.com/forum/showthread.php?t=1077&highlight=truck+problems
Tube project idea (getting scale look right).
http://www.rccrawler.com/forum/showthread.php?t=1216&highlight=tube+project+idea
Series or parallel?
http://www.rccrawler.com/forum/showthread.php?t=1990&highlight=series+paralle
Motor wiring (forward/reverse rotation Q's).
http://www.rccrawler.com/forum/showthread.php?t=1058&highlight=motor+wiring
Limiting straps.
http://www.rccrawler.com/forum/showthread.php?t=5823
Fender trim materials.
http://www.rccrawler.com/forum/showthread.php?t=2498&highlight=fender+materials
R/C License plates.
http://www.rccrawler.com/forum/showthread.php?t=3120&highlight=license+plates
Cheapest crawler.
http://www.rccrawler.com/forum/showthread.php?t=3641&highlight=zipzap
Also, there are a few more in this post
http://www.rccrawler.com/forum/showthread.php?t=3406
Now with all this in this post, I have just barely scratched the surface to the wealth of info that is on this board. There is A TON more info and this post could go on forever, but why should it? If people can't take some time to help themselves, why should anyone else take thier time to help that person?
So if you have trouble finding the "search" button, let me help you find it here http://www.rccrawler.com/forum/search.php?
You can even search the whole board and not have to go to every section and do seperate searches. Trust the members that have been around for a long time and tell you, The search button does work. I found all this info in less than 30 mins
But for some reason, I feel I just wasted 30 mins, because we all know that people don't like to read
Anyway -
Clods
TXT
Maxx
TLT
what is a GD600?
Lexan body work.
Balancing weight.
Making links.
Brazing stainless?
Bending aluminium.
Cutting aluminium.
Servo saver or not.
Series or parallel?
Limiting straps.
R/C License plates.
Cheapest crawler.
