Thermal arc welders?
xgerstandtx
Marshalltown
Hey guys, I am looking to purchase a TIG welder and decided that I probably don't need an AC machine as I will doing mostly steel bicycle frames.
I have narrowed down my choices to:
http://victortechnologies.com/Therm...cess Welding System TSB_(84-1103)_Mar2012.pdf
This is a 3in1 machine (mig,tig,stick) I already have a reliable Hobart MIG so I don't think I need this one.
The input/output and duty cycle is very similar to this machine:
Products
I am leaning to the 161s any tips or experience? Thank you.
If you start tiging you will endup wanting to do aluminum. So I'd get one that can do AC. Other than that I can't give eny recommendations for a certain one. I've always used then ones that my employers already have.
Checkout the forum at everlastgenerators.com
I have the multiprocess machine with no issues at all.
It does dc tig, stick, and plasma cut. I already had a mig welder.
And since you have a mig as well the plasma will be handy to have.
I recently bought the Thermal Arc 95s, their smallest version. It is a lift TIG/scatch start setup. I had never ran a TIG before that but found it fairly easy to use. I wanted it to more easily weld the thin sheetmetal parts I wanted to start incorporating. Worked out pretty well so far.
