Tires rubbing portal box
Broncoguru
US
I recently bouht rc4wd rally wheels for my trx4 and i put rc4wd iroks on them, now my tires are rubbing where the front steering link meets the portal box is there anyway i can fix this?
Sent from my SM-T350 using Tapatalk
MIP makes slightly longer stub axles which will push the wheel out a bit.
You can also get wider hubs for your wheels to push them out more. Vanquish, Locked Up, Brood, Injora, and others make different width wheel hubs.
Would these add enough
Sent from my SM-J737A using Tapatalk
With the groove that already exists in your current tires, any amount of additional width will help you out. You aren't going to dig that groove any deeper if you move the wheels/tires away from their current position. If you plan on replacing those tires in the future though, you might have to go a little wider.
Just to help you avoid potentially making the same mistake I almost made buying these exact hexes, these are +4mm over stock. (Stock 4mm + 4mm = YR 8mm wide)
Sent from my LM-V600 using Tapatalk
With the groove that already exists in your current tires, any amount of additional width will help you out.....
This is GREAT info, that should be mandatory on "package claims". / Like a Nutrition Facts label. Lol
Read-Up! Mod-On! Crawl EXCESSIVELY!
Always happy to help!
I too, would appreciate knowing the dietary information of my wheel hexes. It's important to track your daily intake of machined brass. [emoji16]
