maverick67
Please excuse this long post, but I want to make it as clear as possible in the hope that Castle will address the issue. I know the MMP is more or less a discontinued product, but I can't help but think a simple firmware modification is all that's required to improve the following issue:
BACKGROUND: I have tried several different sensored brushless motors with both my MMP and Mamba X (MX), here is a huge difference I've spotted when both ESCs are in Normal Reverse mode. Because there's no on-the-fly drag brake adjustment on the MMP, I like to set a very low drag brake setting (0-10%) and then rely on normal braking when required (ie: use normal reverse mode).
With the MX, when rolling slowly down a slope, with throttle at neutral, vehicle can be slowed down using normal braking multiple times. Throttle input sequence would be: Neutral-Brake-Neutral-Brake etc.... Basically mimics what a driver would do and the expected response in a real car going down a hill.
However, with the MMP in the exact same situation, the above throttle input would result in the first brake application doing the same thing, BUT, then the second brake application onwards would cause the vehicle to go into reverse (I guess a bit like crawler reverse).
From the symptoms, the only conclusion I can draw is that the MX can detect through the sensor cable that the vehicle is rolling down hill and so no matter how many times reverse throttle is applied, only the brakes are applied. In fact, I've found that if the brake setting is set to a level where its insufficient to completely stop the vehicle on the hill, then its actually impossible to engage reverse.
On the other hand, the MMP seems to operate with no regard to the sensor wire which means that ESC has no idea of the actual speed/direction of the vehicle. Therefore, after the first normal brake application, it will just arbitrarily apply reverse power from the second reverse throttle input onwards.
Am I making any sense at all? Can anybody else relate to what I'm saying? Thanks very much!
