toyofast
Picked this up from a fellow ORCRC member a while ago and since then I have not stopped playing with this little rig. I'm not sure why I'm so attached to to but I can't leave it alone.... makes me smile every time I see it.
Run down:
-ball bearings
-Spektrum high torque servo
-Tekin 45-turn motor
-RC4WD gear reduction
-old school Super Rooster ESC
-Pro-Line Flatirons on stock Pajero wheels
-3mm "lift" plus preloaded shocks
-Losi shocks in the rear
-Lower rear links mounted high and out of the way on the chassis
-Body is trimmed to fit tires
-Built adjustable upper camber links, has made a difference!
-PNW waterproofed.
Maybe more but minor stuff.
Some pictures!
Spare is a narrowed stock TLT tire and wheel. It's light, narrow and functional!
Oh SNAP!! Look at that flex up the stacked tires!
Here you can see the wider Traxxas hexes that are used to widen the stance ever so slightly. Also if you look near the bottom of the skid plate, close to the lower a-arm you can see a copper spacer which gives me the 3mm "lift". Seems to keep the suspension moving more smoothly, only down fall is that it just mean that the front suspension is 3mm closer to the ground. Not a big deal since this thing seems to wheel pretty good.
Adjustable upper camber links. Every CC-01 owner should do this easy & cheap mod.
In the rear you see the Losi shocks and the rear upper links that are next on the chopping block.
Videos:
http://vimeo.com/4794756
http://vimeo.com/4666854
Run down:
-ball bearings
-PNW waterproofed.
Some pictures!
Videos:
