Toyota Tundra recall
jhtoy
In my shop
So I caught wind of a recall on some 110,000 Toyota Tundra trucks from 2000 to 2003 concerning frame rust around the spare tire carrier.Mine is an 01 so I called the dealer this morning and they had me bring it right in for inspection.The manager put my truck on the lift and brought me out to the shop to see for myself.Yikes...I knew it was gettin kinda crusty under there but with the truck on the lift you could really see how bad the rust was.I guess people have had the spare tire drop out while driving causing major accidents!Since I was the first tundra brought in for recall the manager wasn't really sure what the best course of action was.He is having a Toyota rep come out tommorrow to look at the truck.There was talk of either giving me 150% of blue book for the truck or replacing the frame.Not sure how I feel about the dealer replacing the frame,I forsee endless problems.I don't really want a new truck either,mine is a Tundra Limited customized just the way I want it.Ivan Stewart wheels,full custom Bilstein suspension,billet grill etc.It will be interesting to see how this plays out.One nice thing though,they gave me a 2010 Tundra to drive until they figure this out,pretty sweet truck!
Hell, if boyband can do it a frame swap can't be that hard :flipoff:
The good thing about being the first is that the tech won't know any shortcuts, so it'll get done right.
I am hoping to hear from Mike(1bjb) since he has dealt with this firsthand.Holla back Mike........
I have had two tundras come in...one the lady bought the truck in saying there was a hole. Well it had a hole alright...it rotted through the 1st layer of the C right behind the cab. A few smacks later with my Mac hammer and it was through all the way. I then had another truck come in (an 01/170k), and it was rotting right smack in the middle of the rear wheel well on each side... Didnt say anything about that because he just came in bitching that his fabtech coil overs were leaking... I told the writer that it wasnt worth investing in another set of coil overs.
As far as I know they werent doing anything about them??? I will check on TIS tomorrow and see what I can find out for you "thumbsup" If they are it is news to me.
Drive that thing down here, Ill swap the frame :mrgreen:
if you are worried about the custom stuff just take them off what you can at home then go to the dealer and take your wheels off and leave it on blocks, or on their lift until they put wheels on it.
when i went to have my tacoma looked at for the same frame rust issue, i asked the dealer about all the aftermarket i had on it, and he said "they crush the trucks anyways, so take it all off"
What the hell Toyota? I thought the rust problems were over? Yet another reason I won't buy something new
Did Toyota put any rustproofing crap on the frames from factory or were they just using shitty steel?
Here guys...
Nothing mentioned about frame replacements. Most for those that live in the SALTY road areas.
Special Service Campaign (Safety Recall)
Certain 2000 through 2003 Model Year Toyota Tundra Vehicles in Severe Cold Climate States
Excessive Corrosion of the Rear Cross-Member (Spare Tire Carrier)
******URGENT******
On November 16, 2009, Toyota filed a Defect Information Report (DIR) with the National Highway Traffic Safety
Administration (NHTSA) informing the agency of our intent to conduct a voluntary Safety Recall on certain 2000 - 2003
Model Year Toyota Tundra vehicles registered in specific Severe Cold Climate States. Only vehicles registered in the
following 20 Severe Cold Climate States and the District of Columbia are affected.
CT, DE, IL, IN, KY, MA, MD, ME, MI, MN, NH, NJ, NY, OH, PA, RI, VA, VT, WI & WV
Condition
On certain 2000 through 2003 model year Tundra vehicles operated in cold climate areas with high road salt use
(Severe Cold Climate States) excessive corrosion may be exhibited on the rear cross-member. In the worst case, the
spare tire stowed under the truck bed may become separated from the rear cross-member. Eventually, excessive
corrosion of the rear cross-member may also affect the functionality of the rear brake line at the proportioning valve.
Exposure to cold climate and high road salt usage conditions are primary contributors. This is unrelated to, and
separate from normal surface rust which is commonly found on metallic surfaces after some years of usage and/or
exposure to the environment.
There are approximately 110,000 Toyota Tundra (model year 2000 2003) vehicles registered in the Severe Cold
Climate States.
Status
Owners of the affected vehicles will be notified by first class mail starting in December, 2009. They will be instructed
to bring their vehicles to a Toyota dealer for an initial inspection of the rear cross-member. During this inspection, the
rear cross member including the surrounding components such as the brake line at the proportioning valve (which is
mounted on the cross-member assembly) will also be inspected. Based upon the inspection, Toyota will do one of the
following at no charge to vehicle owners:
1. If there is no significant corrosion of the rear cross member assembly, the owner will be notified of that fact and
told that he or she will subsequently be requested to bring the vehicle back to the dealership so that a corrosionresistant
compound can be applied to the rear cross-member when it becomes available.
2. If significant corrosion is detected such that the rear cross-member can no longer safely support the spare tire
and replacement components are available, the rear cross-member assembly will be replaced.
3. If significant corrosion is detected such that the rear cross-member can no longer safely support the spare tire
and replacement components are not available, a temporary solution, such as the removal of the spare tire and
relocating it to the truck bed or other area, will be performed until parts are available. The owner will be notified
as soon as parts are available.
4. In those relatively rare cases where the rear cross-member is significantly corroded and can no longer safely
support the spare tire, but the rear cross-member cannot be replaced due to excessive frame corrosion at the
mounting locations (e.g., if the side rails are too damaged), Toyota will develop an appropriate remedy for those
vehicles.
Owners of subject vehicles in other states will receive a separate notification including details on how to obtain an
inspection if they desire. Toyota will perform the same inspection and repair for those vehicles at no charge as well.
A dealer package which includes detailed technical instructions and reimbursement procedures will be sent to you in
December, 2009. Owner notifications will begin in December 2009, following the dealer notification.
Yeah I live in NJ,damn road salt! My spare tire assembly is certainly rusty and it seems Toyota will do something about that.However,when they inspected my truck they found corrosion on the crossmembers and shock towers as well.Still waiting to hear from the dealer.As I said before the dealer gave me a 2010 Tundra to drive,this thing has 381 horses,freakin thing flies!:shock: If I do end up purchasing a new truck I am not sure if I would get the Tacoma or the Tundra.The new Tacos are about the same size as my old Tundra so I really wouldn't be downsizing.Also,the V6 puts out as much power as my old 5.7 V8.
I know alot of guys will bash Toyota about this but I cannot.After owning 4 Toyota trucks I feel there reliabilty and durability is far above any other brand,I should know I've owned them all,Ford,Chevy,Dodge,Nissan. I don't know what the outcome of all this will be but for Toyota to address problems on a nine year old truck is comendable.Oh what a feeling!:)
10/4 on the salt. NJ and PA (where I live) isn't bad salt wise compared to some areas more north. Spend some time in parts of Canada and you'll see some harsh conditions. Don't take long for a car to go to crap up there. I'd buy the Taco over the Tundra if you don't need the extra size of the Tundra. The V6 in the Taco do indeed put out decent power.
Mt Fords frame is coated with a a black tar like substance along with the paint. I still drop the spare every year to check tire pressure and clean it. Its amazing how much crap gets flung up on the spare.
If there is one thing about Toyota, it is that they do right when they F' up. I have no doubt that they will take care of the issue in one way or another.
It's horrible here, they put so much salt down the road turns almost white.
And drinks plenty of gas
So I still have a couple more years with Ohio winters before my 08 Tundra rusts out right? I wouldn't trust the Toyota dealer where I bought my truck to change my oil, let alone replace my frame.
I'm getting a free sample of this to try.
http://www.fluid-film.com/index.html
Some guys coat the underside of their truck with it before winter to help keep the corrosion at bay. I'm going to spray the stuff up the drain holes in the door of my truck so the bottom of the doors don't rust. I'll see how it works.
I can't imagine how any of you guys that live in the salty areas handle it. Seriously, we have had a few out of town rigs in the last few weeks, plates showing NJ, NY and IL. Freaking 3-4 year old rigs are freaking rust buckets IMO.
I think I love cars/trucks enough that I could NOT live in the salted area. I love my rust free 1967 Chevelle that was a DD from 1967-1995 by my grandmother.
I've known a few people that used to live way up in the northers states. Every single one of them had a nice car they took care of and only drove in the spring/summer/fall, and another piece 'o' crap that they'd schlep around in exclusively during the winter. One guy said he'd have to get a new "winter car" every couple of years because they would fall apart from all the rust.
I might hold off on that it might trap what ever moisture is in there and make it rust even faster. I have heard that was a problem with the old zeibart stuff. People would get the doors done and next season they would rust out horribly.
